[gdal-dev] gdal 1.11 unable to read netcdf files
00darki alex.jong0019 at gmail.com
Fri Jun 27 07:10:46 PDT 2014
I'm new on the mailing list, and to begin i want to apologize for my bad
english skill.
I hope you could help me, i've a problem with gdal to read netcdf (.nc)
files.
In gdal_formats.txt , i found the line :
"netCDF (rw+s): Network Common Data Format"
But if i run *gdalinfo.exe --formats* , netcdf driver doesn't appear.
And if I try something on a netcdf file :
*d:\GDAL\gdal-1-11\bin\gdal\apps>gdalinfo.exe D:/GDAL/MapServer/mnt00000.nc
ERROR 4: `D:/GDAL/MapServer/mnt00000.nc' not recognised as a supported file
format.
gdalinfo failed - unable to open 'D:/GDAL/MapServer/mnt00000.nc'.*
and same thing with :
NETCDF:"D:/GDAL/MapServer/mnt00000.nc"
ERROR 4: `NETCDF:D:/GDAL/MapServer/mnt00000.nc' does not exist in the file
system,
and is not recognised as a supported dataset name.
gdalinfo failed - unable to open 'NETCDF:D:/GDAL/MapServer/mnt00000.nc'.*
But i've a file called "gdal_netCDF.dll" in gdal plugin and a file
"netcdf.dll" in bin directory..
I don't understand why gdal couldn't read any netcdf file ..
I'm using gdal version 1.11 and windows 7 x64.
Thank you for any help :)
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-1-11-unable-to-read-netcdf-files-tp5148406.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
