[gdal-dev] gdal 1.11 unable to read netcdf files
Etienne Tourigny etourigny.dev at gmail.com
Fri Jun 27 07:51:56 PDT 2014
It would help if you tell use how you installed gdal-1.11. Also where did
this gdal_formats.txt file come from?
On Fri, Jun 27, 2014 at 11:10 AM, 00darki <alex.jong0019 at gmail.com> wrote:
> Hi,
> I'm new on the mailing list, and to begin i want to apologize for my bad
> english skill.
> I hope you could help me, i've a problem with gdal to read netcdf (.nc)
> files.
> In gdal_formats.txt , i found the line :
> "netCDF (rw+s): Network Common Data Format"
> But if i run *gdalinfo.exe --formats* , netcdf driver doesn't appear.
> And if I try something on a netcdf file :
> *d:\GDAL\gdal-1-11\bin\gdal\apps>gdalinfo.exe D:/GDAL/MapServer/
> mnt00000.nc
> ERROR 4: `D:/GDAL/MapServer/mnt00000.nc' not recognised as a supported
> file
> format.
> gdalinfo failed - unable to open 'D:/GDAL/MapServer/mnt00000.nc'.*
> and same thing with :
> NETCDF:"D:/GDAL/MapServer/mnt00000.nc"
> ERROR 4: `NETCDF:D:/GDAL/MapServer/mnt00000.nc' does not exist in the file
> system,
> and is not recognised as a supported dataset name.
> gdalinfo failed - unable to open 'NETCDF:D:/GDAL/MapServer/mnt00000.nc'.*
> But i've a file called "gdal_netCDF.dll" in gdal plugin and a file
> "netcdf.dll" in bin directory..
> I don't understand why gdal couldn't read any netcdf file ..
> I'm using gdal version 1.11 and windows 7 x64.
> Thank you for any help :)
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-1-11-unable-to-read-netcdf-files-tp5148406.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140627/ac9670c2/attachment.html>
