[gdal-dev] gdal 1.11 unable to read netcdf files
Etienne Tourigny etourigny.dev at gmail.com
Fri Jun 27 11:00:48 PDT 2014
If these plugin files came from gisinternals and netcdf is not supported
without moving the plugin files to another directory, then that is a bug in
gisinternals. Perhaps Tamas can comment on this?
Etienne
On Fri, Jun 27, 2014 at 12:11 PM, 00darki <alex.jong0019 at gmail.com> wrote:
> ..I found a solution, simply copy .dll files in a subdirectory called
> /gdalplugins in the /apps directory .. it seems to works fine (with an
> error
> on gdal_GEOR.dll)
> *d:\GDAL\gdal-1-11\bin\gdal\apps>gdalinfo.exe D:/GDAL/MapServer/
> mnt00000.nc
> ERROR 1: Can't load requested DLL:
> d:\GDAL\gdal-1-11\bin\gdal\apps\gdalplugins\gdal_GEOR.dll
> 193: %1 nÆest pas une application Win32 valide.
> Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
> Driver: netCDF/Network Common Data Format
> Files: D:/GDAL/MapServer/mnt00000.nc
> Size is 4321, 2161
> Coordinate System is `'
> Metadata:
>   NC_GLOBAL#latitude_max=90
>   NC_GLOBAL#latitude_min=-90
>   NC_GLOBAL#longitude_max=180
>   NC_GLOBAL#longitude_min=-180
>   profondeurs#desc=GRILLE
>   profondeurs#name=Profondeur
>   profondeurs#units=metre
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 2161.0)
> Upper Right ( 4321.0,    0.0)
> Lower Right ( 4321.0, 2161.0)
> Center      ( 2160.5, 1080.5)
> Band 1 Block=4321x1 Type=Float32, ColorInterp=Undefined
>   NoData Value=9.969209968386869e+036
>   Metadata:
>     desc=GRILLE
>     name=Profondeur
>     NETCDF_VARNAME=profondeurs
>     units=metre*
> Thank you for your answer :)
> Problem solved
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-1-11-unable-to-read-netcdf-files-tp5148406p5148434.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140627/957acfda/attachment.html>
