[gdal-dev] Bus Error (memory error)
Jürgen E. Fischer jef at norbit.de
Sat Mar 1 05:03:48 PST 2014
Hi Even,
On Sat, 01. Mar 2014 at 12:58:20 +0100, Even Rouault wrote:
> > Maybe the disk errors aren't even on the data, but on the binaries.
> Eh, that would be the 0.1% case where the software isn't the cause of the
> failure ;-)
hehe.  but sda might be the system disk that is dying - high sector, but maybe
dual boot.  And if gdal binaries are not yet affected (QGIS already doesn't
start anymore), I figure the probability that it will happen soon is raising
with every access.
Not sure if it's a must to work correctly under such circumstances, but if so
[1] could be used to test.
Jürgen
[1] http://stackoverflow.com/questions/1870696/simulate-a-faulty-block-device-with-read-errors
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
