[gdal-dev] Bus Error (memory error)
Gpetr gkpetrak at gmail.com
Sat Mar 1 07:20:55 PST 2014
Hello Even and Jürgen,
thank you for your quick replies.
I'll try to give you more details about the error and my system.
My system:
Architecture: x86_64
CPU: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Disk: ST9500325AS (/dev/sda)
Os: OpenSuse 12.3
I'm using GDAL 1.10.1 - 1.37 and QGIS 2.2 and I process GeoTIFFs raster
images.
The bus error occured for first time, when I executed the *nearblack* gdal
command. I typed exactly the following:
--> nearblack -of GTiff -setalpha -o Natural_Color_432_2.tif
Natural_Color_432.tif
After that, the bus error is everywhere on Gdal.
I checked the bus error with gdb and I receive the following outputs:
On QGIS:
Starting program: /usr/bin/qgis
Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
Try: zypper install -C
"debuginfo(build-id)=0a23c4e8300b31613d800697d835b384e921407e"
Program received signal SIGBUS, Bus error.
0x00007ffff7de5fbc in _dl_relocate_object () from
On Gdal (gdalinfo command):
Starting program: /usr/bin/gdalinfo
(gdb) bt
#0  0x00007ffff7de5fbc in _dl_relocate_object () from
#1  0x00007ffff7ddec52 in dl_main () from /lib64/ld-linux-x86-64.so.2
#2  0x00007ffff7df00be in _dl_sysdep_start () from
#3  0x00007ffff7ddfd86 in _dl_start () from /lib64/ld-linux-x86-64.so.2
#4  0x00007ffff7ddc528 in _start () from /lib64/ld-linux-x86-64.so.2
#5  0x0000000000000001 in ?? ()
#6  0x00007fffffffe191 in ?? ()
#7  0x0000000000000000 in ?? ()
I think that a  C part of code contrasts with a python part of code. Today I
realized that my Django's development server which is a python program too,
can not start and I receive a bus error again.
Any ideas ?
Thank you in advance,
George
View this message in context: http://osgeo-org.1560.x6.nabble.com/Bus-Error-memory-error-tp5106728p5106779.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
