[gdal-dev] New compression library based on gdal design
Norman Vine nhv at cape.com
Sat Mar 1 08:11:49 PST 2014
GDAL core is mostly C++
but it is exposed thru a 'C' interface for stability reasons
e.g. the 'C API' is stable thru major releases whereas the
underlying implementation may change
On Mar 1, 2014, at 11:07 AM, Aaron Boxer <boxerab at gmail.com> wrote:
> Thanks, Norman!  That is very useful.
> I haven't decided yet whether to use C or C++ for the library language.
> Is the gdal core C or C++?  I am tending to C over C++, just for portability.
> But I want to avoid the spaghetti code I see in OpenJPEG.
> Any comments on this?
> Thanks again,
> Aaron
> On Sat, Mar 1, 2014 at 10:37 AM, Norman Vine <nhv at cape.com> wrote:
> These should help
> http://gdal.org/gdal_drivertut.html
> http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/openjpeg/openjpegdataset.cpp
> On Mar 1, 2014, at 10:27 AM, Aaron Boxer <boxerab at gmail.com> wrote:
>> Hello,
>> I recently started developing an open source jpeg2000 compression library using opencl.
>> I would like to base the library design on the very successful gdal library design.
>> Can anyone recomend any resources to help me to grok the high level design of gdal?
>> Thanks so much,
>> Aaron
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140301/2b11b98f/attachment.html>
