[gdal-dev] Something wrong with writing a big raster into PDF
Even Rouault even.rouault at mines-paris.org
Fri Mar 7 05:10:34 PST 2014
Hi Jukka,
did you try with -co TILED=YES ?
Even
> Hi,
> I can't make usable pdf files from some original maps and I do not
> understand what goes wrong.
> I am testing on Windows 7 and GDAL-dev from gisinternals, both 32 and 64
> bit. Images are like this one:
http://kartat.kapsi.fi/files/taustakarttasarja/taustakartta_80/5m/etrs89/png/UM5L.png
> Command can be simplified to
> gdal_translate -of pdf UM5L.png UM5L.pdf
> Everything seems to go alright and gdalinfo shows normal information from
> the pdf. However, if I open the UM5L.pdf file with Acrobat Reader it does
> not show a map. Everything is just pure white.
> I planned to check what happens if read the map back from pdf as
> gdal_translate -of gtiff um5l.pdf um5l.tif
> After fifteen minutes I estimate that the output will be ready after an hour
> or so which is all too slow for a Corei7 CPU and 8GB of RAM.
> I had another try with the same binaries with a small png file (2000x2000
> pixels) and conversion into pdf was fast and successful. Is there perhaps
> something that does not scale up properly when the raster size gets bigger?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
