[gdal-dev] Heuristics to classify raster data ?
Vincent Mora vincent.mora at oslandia.com
Sat Mar 8 01:02:09 PST 2014
On 07/03/2014 19:49, Even Rouault wrote:
> Le jeudi 06 mars 2014 20:50:45, Joaquim Luis a écrit :
>> Even,
>> Did not get it all. You want a method that allows you to tell between a
>> map and aerial/satellite image?
> Yes exactly
>> I believe the k-means algorithm would produce quite good results on maps
>> as is expectable that individual clusters would have low variance.
> Hum, I read a bit http://en.wikipedia.org/wiki/K-means_clustering and not
> being familiar with it, it is not obvious how that could lead to the binary
> result I expect ;-) I was hoping for a ready-made solution for my problem. I'm
> kind of demanding tonight ;-)
Are maps better candidates for image compression than natural images ?
> Thanks anyway,
> Even
