[gdal-dev] Moving the poles
Laskaris francisrayder at yahoo.co.uk
Sat Mar 8 19:29:16 PST 2014
I am trying to do a crazy "What if...?" climate model experiment that
involves changing the location of the poles. So, mind you, I am not merely
trying to change the coordinate display and use a rotated pole grid. I am
actually trying to locate the pole somewhere else (for instance, in
Australia), and transform all the elevation etc. data accordingly to new
coordinates.
Is it possible to transform a geotiff or netcdf file with GDAL to achieve
this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Moving-the-poles-tp5127897.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
