[gdal-dev] Moving the poles
Etienne Tourigny etourigny.dev at gmail.com
Sun Mar 9 10:12:54 PDT 2014
Not sure about gdal, but cdo [1] can do this on netcdf files.
have a look at the docs and see the section grids.
You would probably have to define a rotated pole grid, then apply that grid
on your file (using setgrid), then regrid to a normal lat/lon grid using
one of the grid operators like interpolate, remapnn, remapbil, depending on
your data.
But I've never done this though...  There us a forum there if you have
questions, someone probably has an answer.
[1] https://code.zmaw.de/projects/*cdo*
On Sun, Mar 9, 2014 at 12:29 AM, Laskaris <francisrayder at yahoo.co.uk> wrote:
> I am trying to do a crazy "What if...?" climate model experiment that
> involves changing the location of the poles. So, mind you, I am not merely
> trying to change the coordinate display and use a rotated pole grid. I am
> actually trying to locate the pole somewhere else (for instance, in
> Australia), and transform all the elevation etc. data accordingly to new
> coordinates.
> Is it possible to transform a geotiff or netcdf file with GDAL to achieve
> this?
> http://osgeo-org.1560.x6.nabble.com/Moving-the-poles-tp5127897.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140309/ec8ff488/attachment.html>
