[gdal-dev] Moving the poles
jluis at ualg.pt jluis at ualg.pt
Sun Mar 9 11:43:54 PDT 2014
Not sure if that's what you want but it worth having a look at GMT's
"grdrotater"
Joaquim
> Thank you for your reply. However, I have already tried CDO and it does not
> work for what I am trying to do.
> When you apply a rotated pole grid to a file with CDO, it does not change
> any of the data in the fields. It does not do any kind of "reprojection", as
> it were. All it does is add info about the location of the rotated pole to
> the file header, and then the file gets displayed accordingly by netcdf file
> viewers. Then, when you regrid to a normal, regular lat lon grid, the
> rotated pole is removed again from the header, and you are left with the
> very same file you started with.
> http://osgeo-org.1560.x6.nabble.com/Moving-the-poles-tp5127897p5127937.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
