[gdal-dev] gdal_merge.py can not work
ridgewang ridgewang at gmail.com
Sun Mar 9 21:47:37 PDT 2014
     I want to use gdal_merge.py to merge two image files. But it reports cannot load _gdal library and %1 is not     a valid win32 module. Here the %1 means the _gdal, maybe.  In python CUI, I run 'import osgeo.gdal' or 'import gdal' command, it reports the same error information.
     I use gdal 1.10.1 1400(vc2005) win32 version on win7 64bit OS, and the python version is 2.76.
    Any suggestions is appreciated.
Ridge
发自我的 iPhone
