[gdal-dev] gdal_merge.py can not work
Chaitanya kumar CH chaitanya.ch at gmail.com
Sun Mar 9 23:13:10 PDT 2014
Ridge,
How did you install GDAL?
This usually happens when python cannot find the gdal libraries. Setting
PYTHONPATH env variable may help.
On Mon, Mar 10, 2014 at 10:17 AM, ridgewang <ridgewang at gmail.com> wrote:
> Hi,
>      I want to use gdal_merge.py to merge two image files. But it reports
> cannot load _gdal library and %1 is not     a valid win32 module. Here the
> %1 means the _gdal, maybe.  In python CUI, I run 'import osgeo.gdal' or
> 'import gdal' command, it reports the same error information.
>      I use gdal 1.10.1 1400(vc2005) win32 version on win7 64bit OS, and
> the python version is 2.76.
>     Any suggestions is appreciated.
> Ridge
> 发自我的 iPhone
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140310/026b3385/attachment.html>
