[gdal-dev] Extra Decimal places added to ASCII gdal_translate mosaic
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Mar 11 02:06:55 PDT 2014
> TIFF stores floating point values as IEEE754 floats. Talking about
> significant
> figures doesn't make much sense. You could test using Float64 with the hope
> that 50.597 can be exactly represented as a Float64. Otherwise you'll have
> to
> do the rounding when reading back from TIFF.
Hi Even,
Thanks for the information. I don't pretend to understand the fine details
of floats, but it does seem counter intuitive that a simple 2 or 3 decimal
places can't be accurately represented.
I tried the Float64 but the values are identical (16 significant figures)
even though the filesize is predictably larger.
I guess I'll have to make do, but it does introduce the problem of False
Precision.
Thanks all,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140311/e5b43b0e/attachment.html>
