[gdal-dev] WAsP map output for ogr
Even Rouault even.rouault at mines-paris.org
Tue Mar 11 06:58:31 PDT 2014
Selon Vincent Mora <vincent.mora at oslandia.com>:
> On 11/03/2014 10:39, Even Rouault wrote:
> > If you want to test the compliance of your driver (the read part) with the
> > assumptions of the OGR API, you can go to the apps subdirectory of GDAL and
> > "make test_ogrsf", and then "test_ogrsf a_wasp_file".
> Thanks for the tip.
> It helped me fix some issues, and raises one question: test_ogrsf now
> fails with 'ExecuteSQL() should have returned a non-NULL result', should
> I implement all the sql queries that are specified in
> http://www.gdal.org/ogr/ogr_sql.html for my driver to be OK ?
You should completely remove your ExecuteSQL() implementation. The generic one
in OGRDataSource should be sufficient.
