[gdal-dev] Extra Decimal places added to ASCII gdal_translate mosaic
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Mar 12 06:58:51 PDT 2014
Hi David,
> Here's a crazy idea could you perhaps use mm and then output to an integer
> raster? No problem representing 50597mm.
I like you thinking! But on reflection suspect that would confound a few
too many of our users. It's certainly a nice lateral-thinking solution to
bear in mind for the future though.
Thanks!
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140312/0cb8a082/attachment.html>
