[gdal-dev] [RFC] [GDAL] Idea for GSoC, 2014
Kshitij Kansal kansal.k at gmail.com
Sat Mar 15 12:50:55 PDT 2014
Hello Again,
@Dimitriy - Currently the GDALComputeMatchingPoints  is using the
SimpleSurf algorithm for matching points. Are you proposing that, I should
implement the BRISK and then provide user the option of using either this
or SimpleSurf(already implemented)?
This is indeed a very interesting thought but the problem in this is that,
the GDALComputeMatchingPoints is developed with respect to the correlator
project and I feel that SimpleSurf algorithm implemented there won't work
on my Automatic geo-referencer as I would be considering the Multispectral
Imagery and Large Datasets which are not handled in the current
implementation.* So this will require modification to SimpleSurf as well.*
I hope I have made my doubt clear? Please convey your views on this.
@Chaitanya - In comparison to the SURF, BRISK can definitely handle the
large imagery to great extent. But there is going to be some threshold upto
which this algorithm will work because we must not forget that these
algorithms are developed for Normal RGB images for Computer Vision related
work and there usage to Remote Sensing requires some modification. I will
try to look for this thing in more detail and then get back to you.
Also, should I prepare my initial draft of proposal based this BRISK idea
only?
I have already started work in this direction and will soon post it, for
review.
With Regards,
Kshitij Kansal
Lab For Spatial Informatics,
IIIT Hyderabad
On Sat, Mar 15, 2014 at 12:29 AM, Chaitanya kumar CH <chaitanya.ch at gmail.com
> wrote:
> Kshitij,
> What is the performance of the proposed algorithms for very large rasters?
> If one of them is good with large images that's a cleaner choice without
> all the workaround with scaling the rasters.
> Best regards,
> Chaitanya Kumar CH
> On 15-Mar-2014 12:22 am, "Dmitriy Baryshnikov" <bishop.dev at gmail.com>
> wrote:
>>  Hi,
>> I think we need to decide it here, not to create lot of proposals. The
>> second idea is very interesting. Maybe it worth to create some common
>> interface (or API) to add new methods BRISK, SURF, SIFT etc.
>> You can develop you realisation of BRISK and demonstrate how-to one can
>> use it via such common interface.
>> E.g. in GDALComputeMatchingPoints add enum for algorithms or use exist
>> papszOptions.
>> Best regards,
>>     Dmitry
>> 14.03.2014 17:28, Kshitij Kansal пишет:
>> Hello everyone
>>  Continuing the previous discussion, I would like to propose something
>> and the community's suggestions are welcomed/needed. I can understand that
>> this thread is a little old, so let me remind you that its regarding the
>> automatic geo-referencer idea. The idea is also proposed on the GDAL ideas
>> page (http://trac.osgeo.org/gdal/wiki/SummerOfCode).
>>  Based on the previous discussions, what came out was that we can
>> improve the current implementation of SIMPLE SURF in GDAL which was
>> developed as a part of 2012 GSOC GDAL Correlator project, to support *large
>> data* and *multi spectral imagery*. And then apply this *modified* algorithm
>> for the geo-reference purposes. Now I have been in touch with Chaitanya,
>> who is willing to mentor this project, and there are some things on which
>> we would like to know community's suggestions/response.
>>  There are basically two things that can be done regarding this project:
>>  1. As mentioned above, we can modify the SIMPLE SURF algorithm and make
>> it much better for the geo-reference purposes. Already, a lot had been
>> discussed on this and we have a fairly good idea about what is to be done.
>>  2. One more thing that can be done is that we can implement BRISK
>> algorithm[1] instead of SURF along with the FLANN matcher for this purpose.
>> What advantages this thing offers is that it is fairly fast and gives
>> comparable outputs along with that it works well with fairly large data
>> sets. So we do not need to segment the imagery as we would have done in the
>> case of SURF. Also added to this, this algorithm also has no patent issues.
>> We had a lot of problem regarding patent issues in SIFT/SURF and we
>> discussed them at length on the mailing list as well.
>>  One thing that I fell can be done is that  two proposal can be written,
>> one for each and then community can decide accordingly which one is more
>> useful. Or we can decide it here itself..?
>>  Kindly provide your valuable comments and suggestion..
>>  With Regards,
>>  Kshitij Kansal
>> IIIT Hyderabad
>>   1. http://www.robots.ox.ac.uk/~vgg/rg/papers/brisk.pdf
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140316/b51914a8/attachment.html>
