[gdal-dev] Installing GDAL on Win7
Tamas Szekeres szekerest at gmail.com
Sun Mar 23 10:20:08 PDT 2014
Regarding to gisinternals you may probably use the msi installers to have
GDAL set up easily. Any of the 64 bit packages can be used, but the
MSVC2010 versions are used most frequently.
Best regards,
Tamas
2014-03-23 17:51 GMT+01:00 Mike Flannigan <mikeflan at att.net>:
> I see this is the developers list, so maybe this
> is the wrong place to ask this question??
> I'd like to install GDAL on Win7.  I need to automate
> the conversion of thousands of GeoPDF's to GeoTiff's.
> I can do the automation part in other software if
> necessary, so I just need a basic convert utility.
> I'm going to this page:
> http://www.gisinternals.com/sdk/
> but I don't know which download I need.  I would like a
> 64 bit version.
> Should I use the 2nd item under "GDAL and MapServer",
> which is the "MSVC2005 (Win64) -release" one?  Or
> should I use the 2nd binary item?
> Mike F
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140323/28714526/attachment.html>
