[gdal-dev] Installing GDAL on Win7
Mike Flannigan mikeflan at att.net
Sun Mar 23 18:32:22 PDT 2014
Thank you all.  I got it to work with the following
command:
gdal_translate -of GTiff -co "TILED=YES" -co "TFW=YES" C:\Copy\wp.pdf
C:\Copy\wpt.tif --config GDAL_PDF_DPI 300
It works pretty good.  It converts a 11.1 MB PDF into a
96MB Tiff file that zips up into a 57 MB file.  These files
are about 15 times bigger than the ones I am used to, but
they do have quite a bit of detail and don't have the
blank white space that a 7.5 minute topo has.
These Tiffs are very well georeferenced.  I am pleased.
Mike
On 3/23/2014 7:31 PM, Mike Flannigan wrote:
> Thank you Randal and Tamas.
> I downloaded and unzipped "release-1600-x64-gdal-mapserver.zip
> <http://www.gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver.zip>"
> (Compiled binaries in a single .zip package)
> I see these files in 'C:\Copy\bin\gdal\apps':
> gdaladdo.exe
> gdalbuildvrt.exe
> gdaldem.exe
> gdalenhance.exe
> gdalinfo.exe
> gdallocationinfo.exe
> gdalmanage.exe
> gdalserver.exe
> gdalsrsinfo.exe
> gdaltindex.exe
> gdaltransform.exe
> gdalwarp.exe
> gdal_contour.exe
> gdal_grid.exe
> gdal_rasterize.exe
> gdal_translate.exe
> nearblack.exe
> ogr2ogr.exe
> ogrinfo.exe
> ogrtindex.exe
> testepsg.exe
> I went to this site:
> http://www.staygeo.com/2013/03/convert-geopdf-maps-to-geotiff-with-gdal.html
> and followed the instructions.
> I typed:
> C:\Copy\bin\gdal\apps>gdal_translate -of GTiff -co "TILED=YES" -co
> "TFW=YES" C:\Copy\wpt.tif --config GDAL_PDF_LAYERS_OFF
> "Map_Collar","Map_Frame.Projection_and_Grids" --config GDAL_PDF_DPI300
> It gave an error:
> ERROR 1: --config option given without a key and value argument.
> I'm still working with it.  I don't want tiled - I want the border
> of the drawing included in the GeoTiff.
> Thanks to Tamas Szekeres for maintaining this program.
> Mike
> On 3/23/2014 11:55 AM, Randal Hale wrote:
>> You could usee the OSGEO installer for windows -
>> http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe
>> You can use it to install a whole pile of software (QGIS etc) or just
>> gdal which I think is at 1.10 from this install.
>> Randy
>> Randal Hale, GISP
>> North River Geographic Systems, Inc
>> http://www.northrivergeographic.com
>> 423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale
>> http://about.me/rjhale
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140323/41c7921a/attachment.html>
