[gdal-dev] Installing GDAL on Win7
Norman Vine nhv at cape.com
Mon Mar 24 04:01:00 PDT 2014
On Mar 23, 2014, at 9:32 PM, Mike Flannigan <mikeflan at att.net> wrote:
> Thank you all.  I got it to work with the following
> command:
> gdal_translate -of GTiff -co "TILED=YES" -co "TFW=YES" C:\Copy\wp.pdf C:\Copy\wpt.tif --config GDAL_PDF_DPI 300
I would experiment with adding one of these Creation Options
-co "COMPRESS=LZW"
-co "COMPRESS=PACKBITS"
-co "COMPRESS=DEFLATE"
> It works pretty good.  It converts a 11.1 MB PDF into a
> 96MB Tiff file that zips up into a 57 MB file.  These files
> are about 15 times bigger than the ones I am used to, but
> they do have quite a bit of detail and don't have the
> blank white space that a 7.5 minute topo has.
> These Tiffs are very well georeferenced.  I am pleased.
> Mike
