[gdal-dev] Draft GDAL/OGR class hierarchy for GDAL 2.0
Vincent Mora vincent.mora at oslandia.com
Tue Mar 25 05:13:31 PDT 2014
On 25/03/2014 11:44, Even Rouault wrote:
> Selon Vincent Mora <vincent.mora at oslandia.com>:
>> On 24/03/2014 21:46, Even Rouault wrote:
>>> Hi,
>>> "Release soon, release early", so for people who like UML diagrams (there
>> is
>>> also a prototype of C++ classes for those who don't like UML very much),
>> here's
>>> a blog entry with the outcome of my thoughts for a possible re-organisation
>> of
>>> the GDAL/OGR class hierarchy
> http://erouault.blogspot.ca/2014/03/draft-gdalogr-class-hierarchy-for-gdal.html
>> I don't understand the need for HandleRasterData() and HandleVectorData().
>> Isn't inheriting from GDALEmptyRasterDataset or GDALEmptyVectorDataset
>> sufficient to convey the information that the class doesn't handle those
>> kind of datasets.
>> A call to GetLayerCount()/GetRasterCount() from the class user is
>> sufficient to say "no vector/raster data here", and a dynamic _cast to
>> GDALEmptyVectorDataset/GDALEmptyRasterDataset is even clearer to me, so
>> HandleRasterData()/HandleVectorData() would be a third way to tell the
>> same thing.
> Actually, when thinking more about this, this kind of information should be at
> the driver level, and not at the dataset level. The idea is that there are use
> cases where you want to know if a driver can handle only vector, only raster, or
> both. For example if you still want to have separate Open dialog boxes for
> raster or vector.
>> Also I'm not sure about the names GDALAbstract* since those are partial
>> implementations.
> I know I'm not very good at naming. Do you have an alternative proposal ? The
> issue is that with my draft we end up with a lot of classes and interfaces, so
> it is not obvious to find a good name to reflect their content.
Partial sound ok to me, but I not so good at naming  ?
Considering the number of classes, I gave it some thoughts this morning
and, like Dmitry, thought of merging the Abtract (Partial) into the
interface before realizing that, even if it works (you can overload de
default function in Empty) it's a bit ugly and I ended up preferring
your solution.
An altenative would be to have a Dataset with both aspects and provide
three partial specialisations: one for vector (it will behave like empty
raster) one for raster, and one for both. Code duplications could be
avoided by implementing protected member functions in the Dataset class
and simply calling them in the implementations of partial
specialization. This solution avoid the diamond shaped inheritance
diagram of hell :)
> Even
