[gdal-dev] Compile gdal/ogr with mingw
Even Rouault even.rouault at mines-paris.org
Thu Mar 27 06:08:28 PDT 2014
I haven't tried recently with mingw binaries in Windows, but the build with the
i586-mingw32msvc cross compiler from Linux works and the resulting executable
can pass the regression tests.
> Hi to everyone
> Did somebody compile gdal/ogr with mingw?
> I tried to compile gdal (static/shared) with MinGW without success of
> calling the function OGRRegisterAll() in QT 5.2.1 (C++). Starting the
> binary results in:
>  > The program has unexpectedly finished.
> I used those tutorials:
http://gvsigce.sourceforge.net/wiki/index.php/Compiling_the_C/C%2B%2B_support_libraries
> http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
> http://www.gdal.org/ogr/ogr_apitut.html
> and this shell script with updated version numbers:
http://sourceforge.net/p/gvsigce/code/HEAD/tree/trunk/support/build_scripts/build_gdal_binaries_mingw.sh
> My System:
> Windows 8.1,
> Expat 2.1.0
> GDAL 1.10.1
> Geos 3.4.2
> Openssl 1.0.1f
> PostgreSQL 9.3.4
> Proj.4 4.8.0 (Datumgrid 1.6RC1)
> Sqlite 3080401
> zlib 1.2.8
> Two versions of MinGW 32bit were used at the same time for gdal to compile:
> http://sourceforge.net/projects/mingw/files/
> and
http://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win32/Personal%20Builds/rubenvb/gcc-4.8-release/i686-w64-mingw32-gcc-4.8.0-win32_rubenvb.7z/download
> PATH: C:\MinGW\bin;C:\mingw32\bin
> cheers
> David
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
