[gdal-dev] Open WMS datasets with GDAL Java
Etienne Tourigny etourigny.dev at gmail.com
Thu Mar 27 12:09:58 PDT 2014
Have you tried running in debug mode (CPL_DEBUG=ON)?
On Thu, Mar 27, 2014 at 3:37 PM, Fabio Rinnone <fabio.rinnone0 at gmail.com>wrote:
> Il 27/03/2014 18:27, Even Rouault ha scritto:
> > Selon Fabio Rinnone <fabio.rinnone0 at gmail.com>:
> >> Hi, I'm trying to open datasets of WMS service with GDAL Java warp in an
> >> Android app project with native support. Opening datasets always returns
> >> null datasets. An example WMS is the following:
> >> http://kaart.maakaart.ee/geoserver/wms
> >> I use following statements:
> >> name = "WMS:http://kaart.maakaart.ee/geoserver/wms";
> >> gdal.Open(name);
> >> For my implementation I have adapted python sample code found here[2].
> > I guess you lack a call to gdal.AllRegister(); that will register the
> WMS driver
> > (in Python the registration of drivers is automatically done)
> I'm tried but I have no solved the issue.
> I thought the problem could be related to the inclusion of curl
> libraries (which are required to support WMS), but they are correctly
> included in Android.mk makefile.
> Do you have other suggestions?
> Fabio Rinnone
> 93015 Niscemi CL, Italia
> Skype: fabiorinnone
> Web: http://www.fabiorinnone.eu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140327/71acfa12/attachment.html>
