[gdal-dev] "Syncing" two rasters together...
Etienne Tourigny etourigny.dev at gmail.com
Fri Mar 28 07:09:47 PDT 2014
I've just heard of this project - any reason (aside from licencing issues)
that it could not be added to gdal/ogr itself?
It would be cool for gdal 2.0...
cheers
Etienne
On Fri, Mar 28, 2014 at 6:49 AM, kempenep <kempenep at gmail.com> wrote:
> Hi Jonathan,
> If I understand your question correctly, I might suggest an open source
> tool
> (GPL v3) for this job: pkcrop. It is part of pktools
> (http://pktools.nongnu.org), which is based on the GDAL API. By combining
> pkcrop with pkinfo (also in pktools), you could get what you want in a
> quite
> operational way. pkinfo allows you to define the proper bounding box, x, y
> resolution (pkinfo -i reference.tif -bb -dx -dy). The output can be
> directly
> used within pkcrop using $(command substitution). Not covered areas will
> have a nodata value. You can perform all steps in a one-liner: stacking a
> list of input images to  a multi-layer image using the same bounding box
> and
> spatial resolution
> pkcrop $(pkinfo -i reference.tif -dx -dy -bb) $(for LS in landsat*.tif; do
> echo " -i " $LS;done) -o stacked.tif
> Pieter.
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Syncing-two-rasters-together-tp5131677p5131753.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140328/409b2209/attachment-0001.html>
