[gdal-dev] ogr2ogr doesn't handle logical (boolean) MapInfo tab fields correctly
jonbritton3 jonbritton3 at gmail.com
Fri Mar 28 08:58:57 PDT 2014
I'm trying to use ogr2ogr to load a MapInfo tab file into a PostgreSQL
database using the following command:
However, this produces the following error
The problem field is a Logical field in the source file (with values of T or
F). The actual value of the "crimeOccured" field in the first record is "T",
but ogr2ogr is picking up the integer value 0.
If I convert the tab file into another tab file then it works ok, but it
changes the data type of this field to Character which is not what I want.
Has anybody come across this issue before?
Cheers,
Jon
PS: apologies if this is the wrong message list, I can only seem to find the
dev list.
View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-doesn-t-handle-logical-boolean-MapInfo-tab-fields-correctly-tp5131893.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
