[gdal-dev] "Syncing" two rasters together...
Etienne Tourigny etourigny.dev at gmail.com
Fri Mar 28 09:28:04 PDT 2014
I admit I did not look too much into your application.
In fact, it would be great to add a reference to it (and other software
that uses GDAL) somewhere in the wiki, perhaps the FAQ page?
Perhaps a few of the tools could be added to the utilities or the
functionality be integrated into existing utilities?
I am not sure about the licensing... pktools is licensed under GPLv3 but
GDAL itself is licensed under the a X11/MIT licence which is NOT GPL.
So I am not sure if some parts could be integrated into GDAL without
changing the licence or "corrupting" (nothing negative here) GDAL itself.
Many applications use GDAL/OGR because of its more permissive licence. Any
GPL3 code has to be re-licensed (LGPL seems ok) before inclusion into the
gdal source tree.
cheers
Etienne
On Fri, Mar 28, 2014 at 1:13 PM, kempenep <kempenep at gmail.com> wrote:
> Hi,
> pktools is licensed under GPL v3. To my understanding, code from pktools
> can
> therefore be used GDAL. I'm not sure what this means for the resulting
> code?
> I'm sure we can work it out. All code is in C++, which should facilitate
> this (templates are used though).
> I am happy to contribute to GDAL if there is interest in selecting
> functionality of pktools. In an attempt not to overlap too much with the
> GDAL utilities, pktools focuses on remote sensing processing (e.g., image
> compositing, support vector machine classification,...). The two utilities
> I
> mentioned in my previous reply are a bit of an exception, as they overlap
> with gdalinfo (->pkinfo) and {gdal_translate, gdal_merge.py, gdalwarp}
> (->pkcrop). The main reason for duplicating is this "piping" functionality
> in the example. The output of pkinfo can directly be used in other
> utilities
> such as pkcrop. There is no need to parse the output from gdalinfo first.
> Pieter.
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Syncing-two-rasters-together-tp5131677p5131898.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140328/690b5718/attachment.html>
