[gdal-dev] Draft GDAL/OGR class hierarchy for GDAL 2.0
Mateusz Łoskot mateusz at loskot.net
Fri Mar 28 13:24:36 PDT 2014
On 28 March 2014 21:04, Tim Keitt <tkeitt at utexas.edu> wrote:
> Something to consider is writing an interface that wraps the old code.
> Modern generic approaches make this easy.
> Perhaps evaluate the Generic Image Library and Boost Geometry as candidates?
GDAL is I/O oriented, whereas in GIL and BG, I/O layer is an extension.
Regardless, I've been prototyping GDAL driver for the new GIL I/O
layer (aka GIL.IOv2),
you may check it here
https://github.com/mloskot/boost-gil-workshop/tree/gil-io2-gdal
Best regards,
Mateusz  Łoskot, http://mateusz.loskot.net
