[gdal-dev] OGR: memory leak in OCI driver
Ivan Lucena lucena_ivan at hotmail.com
Tue May 6 08:47:37 PDT 2014
Hi Nicolas,
I received that report a month ago:
"we have found the OGROCISession is never
    released, causing a large memory leak whenever a connection is
    closed.
    As workaround, we added in OGROCISession::~OGROCISession()
        if( hEnv )
                OCIHandleFree((dvoid *) hEnv, (ub4)
      OCI_HTYPE_ENV);"
But they also mention some other memory leaks without an specific location on the code.
Can you try to see if that fix the problem?
Thanks,
Ivan
To: gdal-dev at lists.osgeo.org
Date: Tue, 6 May 2014 15:32:09 +0000
CC: christophe.sandri at spw.wallonie.be; xuan.nguyen at spw.wallonie.be
Subject: [gdal-dev] OGR: memory leak in OCI driver
Dear developers,
                I suspect that there is a memory leak in OCI driver for OGR
                My simplified test case is :
// point A
OGRRegisterAll();
// point B
pDS = OGRSFDriverRegistrar::Open("OCI:USER/PWD at INSTANCE:TABLE", true);
if(pDS)
          OGRDataSource::DestroyDataSource(pDS);
          pDS = NULL;
     else
          fprintf(fOut,"Erreur Open\n");
     // point C
OGRCleanupAll();
// point D
It appears that I lose memory between points B and C, and between point A and D
                B = A + 4 MB
                C = A + 20 MB ( 16 MB lost)
               D = A +19 MB ( 3 more MB lost)
Test was done with GDAL 1.9 under windows (with Oracle 11g)
Can some one have an idea to find and fix this ?
Thank you
By the way,  I received « TICKET_CREATE privileges are required to perform this operation » when I tried to make a ticket (UID nicsim)
Nicolas
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140506/6987c368/attachment-0001.html>
