[gdal-dev] ogr2ogr coordinate system encoding
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed May 7 03:30:04 PDT 2014
mccorb <mccorb <at> cox.net> writes:
> I have shape files that I am wanting to convert to a GML equivalent file. I
> understand how to use the shape file .PRJ files and EPSG info to translate
> coordinate systems and all that is working well.
> However, once converted the coordinates are correct but there is nothing in
> the file (that I can see) to tell if the coordinates in the GML file are in
> lat/lon, utm, or some albers equal area projection etc.
> Is there any way to coerce ogr2ogr to encode the coordinate system info into
> the resultant GML file that matches the coordinates that are there?
> thanks
It seems that srsName in not written automatically but you must set it in
the org2ogr command
ogr2ogr -a_srs EPSG:3067 -f GML test.gml test.shp
Then you will have
<ogr:geometryProperty><gml:Polygon srsName="EPSG:3067">...
Read also about long SRS if you want to use the urn format with GML 3
-Jukka Rahkonen-
