[gdal-dev] ogr2ogr error handling
    Even Rouault
    even.rouault at mines-paris.org
    Wed May  7 15:24:36 PDT 2014
Le mercredi 07 mai 2014 20:30:45, scottm361 a écrit :
> I am a developer on an application that will potentially use ogr2ogr to
> re-project shapefiles (and potentially other ogr supported formats)
> What I am wondering about is the nature of geometry error handling in
> ogr2ogr.  My assumption is that geometry errors are quite common in user
> supplied data, so I am wondering if I need to rethink the automated use of
> ogr2ogr for this purpose.
> Geometry errors that I have encountered so far are:
> ERROR 1: TopologyException: found non-noded intersection between LINESTRING
> (-1.77558e+006 7.46242e+006, -1.77596e+006 7.46259e+006) and LINESTRING
> (-1.77596e+006 7.46259e+006, -1.77593e+006 7.46258e+006) at
> -1775935.412652828 7462582.2040281445
> ERROR 1: TopologyException: side location conflict at -1828580.797204141
> 7355153.6866245456
> ERROR 1: TopologyException: unable to assign hole to a shell
Those are GEOS errors. Are you doing some clipping/spatial filtering too ? What
is your ogr2ogr command line ?
> My questions:
> 1. Does ogr2ogr omit the offending geometries above (or others) when
> -skipfailiures is used in the resulting output
It is difficult to tell for sure. It might depend on the call site that triggers
the error
> 2. Are geometry errors ever "created" by reprojection?  Presumably due to
> floating point error some geometries might be shifted slightly relative to
> each other.
Reprojection could create topological weirdness. For example if you convert a
polygon from polar projection to geodetic projection.
> 3. If the answer to 2 is "Yes", does that mean topology exceptions like
> above are thrown when detected in the source data, AND in the process of
> reprojecting the result?
> 4. Generally speaking, from a reliablility and data integrity standpoint,
> are errors such as these safe to ignore and carry on processes using
> -skipfailiures, or will users be dismayed by things such as missing
> features, which are indirectly a result of their own bad data
> 5. Is there any way to fix the geometry in the OGR context before
> attempting to reproject?
> Thank you !
> Scott Morken
> http://osgeo-org.1560.x6.nabble.com/ogr2ogr-error-handling-tp5139067.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
