[gdal-dev] ogr2ogr error handling
Even Rouault even.rouault at mines-paris.org
Wed May 7 16:01:34 PDT 2014
Le jeudi 08 mai 2014 00:54:50, scottm361 a écrit :
> Hi Even
> Thanks for the reply.
> the command I am using does use clipping, but not spatial filtering:
> gdal\apps\ogr2ogr.exe -overwrite -t_srs
> "layers\NFI_MODIS250m_kNN_Structure_Stand_Age_v0.prj" -clipdst  -2600000
> 5700000 3100000 10500000 -skipfailures
> ".\temp\nfdb_poly_20111223_21094F1A58AE467E\nfdb_poly_20111223_21094F1A58AE
> 467E.shp" "layers\fire\nfdb_poly_20111223.shp"
> Is there an alternative way to do this that I should use?
No, that's fine. Looking at the code, when the GEOS errors occur, it is likely
that the feature whose intersection with the clip bounding box causes the
error will not be written. -skipfailures is not really taken into account in
that matter (the GEOS error does not count as a failure for ogr2ogr, but is
considered as a null intersection)
With some efforts, you could try to extract the feature that cause the issue
and analyze if the GEOS error is logical or if it is a bug.
> Scott
> http://osgeo-org.1560.x6.nabble.com/ogr2ogr-error-handling-tp5139067p51391
> 15.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
