[gdal-dev] PostGIS: COPY mode turned on
Even Rouault even.rouault at mines-paris.org
Sat May 10 08:38:09 PDT 2014
I just wanted to inform that, per http://trac.osgeo.org/gdal/ticket/5460, I've
turned on COPY mode, instead of INSERT, on newly created PostGIS tables, that
should result in faster execution time, typically in ogr2ogr to PostGIS
scenarios.
Setting PG_USE_COPY=NO will revert to INSERT.
In -append scenarios, PG_USE_COPY=YES is still necessary if you want COPY.
Please report if you see bad side-effects of this change.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
