[gdal-dev] Idea: GeoTIFF box in JPEG to add georeferencing
Mon May 12 14:33:08 PDT 2014
Even,
I have no objection to preparing such a GeoTIFF-in-JPEG/PNG mechanism, but
to be honest I find it hard to get excited about GeoTIFF as a broader way
of describing coordinate system information because of the various quirks
with GeoTIFF and the binary opaqueness of GeoTIFF.  However, there is
already precident with LAS and GeoJP2.
Best regards,
Frank
On Mon, May 12, 2014 at 2:18 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le lundi 12 mai 2014 23:05:21, Jukka Rahkonen a écrit :
> > Even Rouault <even.rouault <at> mines-paris.org> writes:
> > > > In light of this, it may be better to use an xml or textual
> > > > representation and embed it inside an XMP block, which is supported
> > > > for many formats[1]. Also it would allow for easier human-reading.
> > > Yes, that's one possibility. Which comes back to GMLJP2 unless there
> are
> > other
> > > standards...
> > > I'd want to build on something that is a "real" standard or a de-facto
> > > standard, but not reinvent everything from scratch.
> > What GMLJP2 gives as a bonus is the axis order trouble and not totally
> > clear interpretation if origin is in the centre (probably it is) or in
> the
> > corner of a pixel, and rectified grid does not support ground control
> > points. Thus GMLJP2 is at least not better in everything, it has also
> > drawbacks.
> Hi Jukka,
> Yes, for all your above reasons, I would prefer to avoid it.
> Although the axis order trouble (the one of EPSG) and interpretation of
> origin
> (pixel center) should be mostly clarified with the revised version.
> As far as ground countrol points are concerned, I've not really looked at
> the
> capabilities of GMLCov, so perhaps there's something in it for that.
> Otherwise, that would be indeed a drawback.
> > -Jukka Rahkonen-
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Geospatial professional services
> http://even.rouault.free.fr/services.html
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140512/c2e132c0/attachment.html>
