[gdal-dev] Gdal-Fortran-Linux Problem
Fabian Niggemann niggemann at vista-geo.de
Wed May 14 05:12:22 PDT 2014
Am 14.05.2014 13:33, schrieb Even Rouault:
> Le mardi 13 mai 2014 15:23:12, Fabian Niggemann a écrit :
>> Hi,
>> I?m trying to link gdal to fortrangis to use the gdal fortran interface
>> on Ubuntu 12.04. I?ve installed gdal Version 1.11. and installed the
>> fortrangis package with disabled shared libraries.
>> If I try now to compile a fortran program(e.g. Command: ifort -I
>> /usr/local/include/ gdal_test.F90 /usr/local/lib/libfortranc.a
>> /usr/local/lib/libshp.a /usr/local/lib/libfortrangis.a
>> /usr/local/lib/libgdal.a) I get a lot of error messages stating
>> undefined references:
>> /usr/local/lib/libgdal.a(genbindataset.o): In function `_Alloc_hider':
>> /usr/include/c++/4.7/bits/basic_string.h:272: undefined reference to
>> `std::string::_Rep::_S_empty_rep_storage'
>> `std::string::_Rep::_M_dispose(std::allocator<char> const&)':
>> /usr/include/c++/4.7/bits/basic_string.h:237: undefined reference to
>> /usr/include/c++/4.7/bits/basic_string.h:246: undefined reference to
>> `std::string::_Rep::_M_destroy(std::allocator<char> const&)'
>> `GDALRegister_GenBin':
> fortangis, I can't believe it ;-)
> Looks like you need to link against libstdc++ too. Can't you dynamically link
> against libgdal.so ? That would avoid that issue.
>> Any help would be appreciated.
>> Regards,
>> Fabian
Hi Evan,
I think you solved my problem. Dynamically linking to libgdal.so helped.
Thanks a lot!
VISTA Geowissenschaftliche Fernerkundung GmbH
Administration: Anton-Ferstl-Str.11, D-82234 Wessling
Office: Gabelsbergerstr.51, D-80333 München
Tel. +49 89 287 794 59 Fax +49 89 523 89 804
eMail: niggemann at vista-geo.de; web: www.vista-geo.de
Amtsgericht München HRB 129776
Sitz der Gesellschaft: Wessling
Geschäftsführung: Dr. Heike Bach
Bankverbindung: Hypo Vereinsbank München
BLZ 70020270 Konto 39042770
USt-IDNr. DE812904252
St.Nr. 11714150105
