[gdal-dev] Update of EPSG database to v8.4
Yann Chemin ychemin at gmail.com
Thu May 15 05:00:33 PDT 2014
Hi Even,
I would be interested to include it. But I see that the 1Mb
uncompressed text is an issue.
If it was OK for the additional Mb in the source code,
what would be the place to look into gdal code to create the patch needed?
Thanks,
Yann
PS: did not copy other lists as I am not a member, registered to proj
ML today though.
On 15/05/2014, Even Rouault <even.rouault at mines-paris.org> wrote:
> Selon Yann Chemin <ychemin at gmail.com>:
>> Hi,
>> is there planetary datum support in this new version (i.e. Moon 2000, or
>> etc.)?
> No, I don't think that the EPSG folks are interested in other planets yet
> But Frank mentionned some time ago (
> http://osgeo-org.1560.x6.nabble.com/IAU-2000-Coordinate-System-Dictionary-td3750798.html
> ) that he wanted to investigate how to deliver the IAU set of planetary
> coordinate systems , but this hasn't been pursued further AFAIK.
> I see there's a version of this file here :
> http://svn.osgeo.org/metacrs/sr.org/srsbrowser/data/IAU2000.wkt
> Even
>> Yann
>> On 14/05/2014, Even Rouault <even.rouault at mines-paris.org> wrote:
>> > Hi,
>> > I've followed the update process of the EPSG SRS database to latest
>> > v8.4,
>> > and
>> > just committed the updated files into libgeotiff, GDAL and PROJ trunk.
>> > Also
>> > submitted to PostGIS.
>> > From what I can see, among many changes and additions, 2 new projection
>> > methods have been added:
>> > * 1051,Lambert Conic Conformal (2SP Michigan)
>> > --> looks very close to standard "Lambert Conic Conformal (2SP)", with
>> > the
>> > addition of a new parameter K, the ellipsoid scaling factor.
>> > * 1052,Colombia Urban
>> > I don't think any of those 2 new methods are currently handled by PROJ,
>> > so
>> > the
>> > new PCS based on those projection methods (3 Michigan SRS, and several
>> > dozains
>> > of Colombia PCS) will not be handled by GDAL nor PROJ.
>> > Regarding GDAL, I've improved the add_esri_column.py script (see
>> > http://trac.osgeo.org/geotiff/changeset/2446), so that we have more
>> > ESRI
>> > DATUM
>> > names. That should make morphing from/to ESRI .prj files a bit better.
>> > Regarding PROJ.4 'espg' and PostGIS spatial_ref_sys.sql files, I've
>> > also
>> > added
>> > the list of SRS that are GEOCCS (GeoCentric) and COMPD_CS (Compound
>> > Horizontal
>> > + Vertical).
>> > Please let me know if you see issues.
>> > libgeotiff:
>> > http://trac.osgeo.org/geotiff/ticket/63
>> > http://trac.osgeo.org/geotiff/changeset/2447
>> > GDAL:
>> > http://trac.osgeo.org/gdal/ticket/5462
>> > http://trac.osgeo.org/gdal/changeset/27322
>> > PROJ:
>> > http://trac.osgeo.org/proj/ticket/236
>> > http://trac.osgeo.org/proj/changeset/2448
>> > Submitted for PostGIS :
>> > http://trac.osgeo.org/postgis/ticket/2737
>> > Best regards,
>> > Even
>> > Geospatial professional services
>> > http://even.rouault.free.fr/services.html
>> > _______________________________________________
>> > gdal-dev mailing list
>> > gdal-dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
