[gdal-dev] How to map Int32 or Float32 GTiff to color map?
Hare, Trent thare at usgs.gov
Thu May 15 12:45:21 PDT 2014
Steve,
   You can think of this very much *as a hack* but I had some success. I
was also testing how to colorize a DEM (or 32bit floating point image)
outside of gdaldem. You would need a script to configure the "lut" line for
each file min/max range though. It does seem to work and you can convert to
other colorized graphical formats (e.g. PNG) using gdal_translate.
example:
(1) create a 3 band VRT of your original file.
> ls dem.tif > mylist
> ls dem.tif >> mylist
> gdalbuildvrt -separate -input_file_list mylist DEM_3bands.vrt
(2) now manually add or script a <LUT> section for each band (see below for
color mapping or [dest value]. Original DEM range was from -8.296 to 4.022)
<LUT>[src value 1]:[dest value 1],[src value 2]:[dest value 2],...</LUT>
example:
<LUT>-8.296:75,-7:0,-3:0,-1.5:204,2:255,3.5:255,3.9:150,4.022:255</LUT>
kind of crazy and really not tested much... Shows how convenient VRTs
continue to be.
Good luck,
Trent
example VRT and tiny DEM (1 MB, odd blip on the right):
https://www.dropbox.com/s/kb8x2vlzmwtl52v/ColorMapping_DEM_toRainbow-BrownWhite_test.zip
screenshot of DEM as converted to PNG:
https://www.dropbox.com/s/i1kldn7th7w5910/1MM3298IOLBYDEM08P2905_colorize.png
The above "rainbow to brown to white" color-ramp in percent would be mapped
at:
# Red stretch pairs. The pattern is percentage:DN
0:75 10:0 40:0 55:204 70:255 85:255 99:150 100:255
# Green stretch pairs. The pattern is percentage:DN
0:0 10:0 30:151 40:204 55:204 70:102 85:0 99:75 100:255
# Blue stretch pairs. The pattern is percentage:DN
0:102 10:204 25:151 40:0 99:0 100:255
Example VRT:
<VRTDataset rasterXSize="373" rasterYSize="625">
  <GeoTransform>-5.0000000000000000e-001, 1.0000000000000000e+000,
0.0000000000000000e+000, 5.0000000000000000e-001,
0.0000000000000000e+000,-1.0000000000000000e+000</GeoTransform>
  <VRTRasterBand dataType="Float32" band="1">
    <NoDataValue>-3.40282265508890E+038</NoDataValue>
    <ColorInterp>Red</ColorInterp>
    <ComplexSource>
      <SourceFilename
relativeToVRT="1">1MM3298IOLBYDEM08P2905.tif</SourceFilename>
      <SourceBand>1</SourceBand>
      <SourceProperties RasterXSize="373" RasterYSize="625"
DataType="Float32" BlockXSize="373" BlockYSize="5" />
      <SrcRect xOff="0" yOff="0" xSize="373" ySize="625" />
      <DstRect xOff="0" yOff="0" xSize="373" ySize="625" />
    </ComplexSource>
  </VRTRasterBand>
  <VRTRasterBand dataType="Float32" band="2">
    <ColorInterp>Green</ColorInterp>
    <ComplexSource>
      <SourceFilename
<LUT>-8.296:0,-7:0,-5:151,-3:204,-1.5:204,2:102,3.5:0,3.9:75,4.022:255</LUT>
    </ComplexSource>
  </VRTRasterBand>
  <VRTRasterBand dataType="Float32" band="3">
    <ColorInterp>Blue</ColorInterp>
    <ComplexSource>
      <SourceFilename
      <LUT>-8.296:102,-6.5:204,-4.5:151,-3:0,3.9:0,4.022:255</LUT>
    </ComplexSource>
  </VRTRasterBand>
</VRTDataset>
On Thu, May 15, 2014 at 12:08 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/15/2014 1:56 PM, Even Rouault wrote:
>> Le jeudi 15 mai 2014 16:25:12, Stephen Woodbridge a écrit :
>>> Hi all,
>>> I'm trying to create a VRT file for a GTiff that is Int32 or Float32 to
>>> add a ColorTable but I seem to be missing a key piece of information.
>>> How are the pixel values mapped to the color table entries? via the
>>> histogram?
>>> My GTiff has noData=-32767 and good values the range from say -5 to 100.
>>> So do I create a color table that is based on the 256 buckets in the
>>> histogram?
>> No way you can use a GDAL color table to map negative values...
>> Perhaps you should use gdaldem color-relief to generate a RGB output. Note
>> that gdaldem color-relief is compatible with VRT output : it uses the LUT
>> mechanism to do so.
> OK, I will look at gdaldem, but not wanting to give up on this yet, is
> there a way to change the NoData pixels from -32767 to say -20 then scale
> 1.0 and offset the value by 10.
> This would make NoData=0
> old   => new
>  -5        5
>   0       10
>   1       11
> 100      110
> then I would have all positive values and the range would be manageable?
> The scale and offset are already supported in VRT, but I'm not sure if it
> is possible to remap -32767 values to a new value.
> Thanks for your response.
> -Steve
>>> So for example I get:
>>> Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
>>>     Min=-32767.000 Max=33.980   Computed Min/Max=-54.985,34.320
>>>     Minimum=-32767.000, Maximum=33.980, Mean=-15887.345, StdDev=16386.592
>>>     256 buckets from -32831.1 to 98.0444:
>>>     1545169 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>>> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>>> 0 0 0 0 0 0 27375 1924356
>>>     NoData Value=-32767
>>>     Metadata:
>>>       STATISTICS_MAXIMUM=33.979999542236
>>>       STATISTICS_MEAN=-15887.344614501
>>>       STATISTICS_MINIMUM=-32767
>>>       STATISTICS_STDDEV=16386.59208246
>>> It seems that the NoData value is included in the stats which really
>>> skews the numbers compressing all my values into two buckets! How can I
>>> avoid that? I want to ignore the NoData values and spread my good values
>>> into the remaining buckets. How can I do this?
>> You can't. There's a ticket I think about the fact we should ignore nodata
>> value in stats.
>>> Thanks,
>>>     -Steve
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140515/d1808ef6/attachment-0001.html>
