[gdal-dev] new landsat-8 metadata format
Daniel Testa danieltesta at suremptec.com.ar
Sat May 17 07:06:35 PDT 2014
> You could have the dataset report subdataset names, like
> "LANDSAT8:LC82300942013289LGN00_MTL.txt:panchromatic",
> "LANDSAT8:LC82300942013289LGN00_MTL.txt:multispectral", etc... And when
those
> names are passed to the Open() methods would return a dataset that would
point
> to the relevant tif.
I see what you mean. I'll try following that path and let you know how it
goes.
Thanks Even.
Best regards,
Daniel.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140517/826bf3ea/attachment.html>
