[gdal-dev] gdal_translate .vrt issue
David Fawcett david.fawcett at gmail.com
Mon May 19 19:37:49 PDT 2014
I am using gdal_translate and a .vrt to take 115 .jp2 files from the USGS,
pull them together and then export a lower resolution .jp2.
This is with GDAL 1.10 on OSX.
gdalinfo --version
GDAL 1.10.1, released 2013/08/26
When I run gdal_translate, it gets about 30% of the way through the process
and errors out saying that it can't open one of the .j2w files.  When I run
gdalinfo on the file, I can open it, and if I run gdal_translate on just
that file, I can successfully export a reduced resolution copy.
The output of gdalinfo is here:
https://gist.github.com/fawcett/beead31741e24394b38e
I can also load the .vrt image into QGIS 2.2 and it loads (slowly of
course).
gdal_translate img_index.vrt mpls34.jp2 -outsize 10% 10% -of JP2OpenJPEG
-co QUALITY=25 -epo
Input file size is 45000, 65000
0...10...20.ERROR 4:
CSLLoad2("/Users/david/projects/mpls_watersheds/data/15TVK830815_201203_0x3000m_CL_1/15TVK830815_201203_0x3000m_CL_1.j2w")
failed: unable to open file.
ERROR 4:
`/Users/david/projects/mpls_watersheds/data/15TVK830830_201203_0x3000m_CL_1/15TVK830830_201203_0x3000m_CL_1.jp2'
not recognised as a supported file format.
gdalinfo 15TVK830815_201203_0x3000m_CL_1.jp2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: 15TVK830815_201203_0x3000m_CL_1.jp2
Size is 5000, 5000
Coordinate System is:
PROJCS["NAD83 / UTM zone 15N",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-93],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26915"]]
Origin = (483000.000000000000000,4983000.000000000000000)
Pixel Size = (0.300000000000012,-0.300000000000186)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  483000.000, 4983000.000) ( 93d12'56.50"W, 45d 0' 0.87"N)
Lower Left  (  483000.000, 4981500.000) ( 93d12'56.32"W, 44d59'12.26"N)
Upper Right (  484500.000, 4983000.000) ( 93d11'47.99"W, 45d 0' 1.00"N)
Lower Right (  484500.000, 4981500.000) ( 93d11'47.82"W, 44d59'12.39"N)
Center      (  483750.000, 4982250.000) ( 93d12'22.16"W, 44d59'36.63"N)
Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
  Overviews: 2500x2500, 1250x1250, 625x625, 312x312, 156x156
  Overviews: arbitrary
Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
The .vrt file contents are here:
https://gist.github.com/fawcett/c8cd5d271b0a89e67779
Does anyone have a suggestion on how to troubleshoot this?  I am wondering
if I am just running out of memory.
Thanks,
David.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140519/11afd576/attachment.html>
