[gdal-dev] OpenJPEG driver
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue May 20 01:10:15 PDT 2014
SAVINAUD Mickaël <mickael.savinaud <at> c-s.fr> writes:
> > IMHO the test case seems to be a bit too artificial to justify any change,
> > unless there are real world cases where that would cause issues.
> Yes it is not a real case but it is a conformance data which allow to
> define if a decoder is JPEG decoding compliant. It helps to verify
> that real less complicated case will be handled properly. For example
> we can see that JP2ECW is not compliant about this point.
Is it a right place to run such tests with GDAL? I understand that JPEG2000
SDKs should pass the tests but isn't GDAL working one step further when it
is utilizing the data ripped off the j2k codestreams?
-Jukka Rahkonen-
