[gdal-dev] Outside of Image Area Warnings gdal_translate
David Fawcett david.fawcett at gmail.com
Wed May 21 04:39:43 PDT 2014
I am running gdal_translate to composite image tiles in a vrt and reduce
the output image size.  I ran it at outsize 50% 50% and received no
warnings.  When I bumped the outsize up to 75%, I got quite a few warnings
like the one below.
Warning 1: Right position of the decoded area (region_x1=5120) is outside
the image area (Xsiz=5000).
This one gave no warnings:
gdal_translate img_index.vrt mpls50.jp2 -outsize 50% 50% -of JP2OpenJPEG
-co QUALITY=25 --config GDAL_MAX_DATASET_POOL_SIZE 10
This one produced warnings
gdal_translate img_index.vrt mpls7575.jp2 -outsize 75% 75% -of JP2OpenJPEG
-co QUALITY=75 --config GDAL_MAX_DATASET_POOL_SIZE 10
GDAL version is 1.10
Any suggestions on how to avoid the warnings?
Thanks,
David.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140521/2b7fa269/attachment.html>
