[gdal-dev] Using GDAL with gridded XYZ that has no 'nodata' values?
Sam Franklin mailinglist.samfranklin at gmail.com
Sat May 24 23:20:13 PDT 2014
Hey Even - well that's embarrassing, it looks like gdal 1.11.0 solves the
problem for those three xyz files that I sent through! Great work, thanks!
However, I've found an example that fails to open here
https://dl.dropboxusercontent.com/u/4086367/gdal_translate_xyz_data04-02.zip
Using gdal 1.11.0 on osx 10.9.3, I receive the following error:
$ gdalinfo data04-02.xyz
ERROR 1: Ungridded dataset: At line 18, X is 516085.000000, where as
516100.000000 was expected (1)
gdalinfo failed - unable to open 'data04-02.xyz'.
I doubt you remember - I chatted to you about this problem at FOSS4G, sorry
it's taken about 9 months to contact you!
Thanks in advance.
S
On 24 May 2014 23:43, Even Rouault <even.rouault at mines-paris.org> wrote:
> Le samedi 24 mai 2014 21:45:45, Sam Franklin a écrit :
> > Greetings. This is my first post to this mailing list, so apologies if I
> > commit a mailing-list faux-pas :)
> > I wonder if anyone can offer a suggestion, as I'm hoping I've missed
> > something obvious.
> > I regularly receive bathymetric DEMs, acquired by acoustic multibeam
> > echosounders (MBES) from offshore geophysical surveys that take the form
> of
> > narrow corridors of survey or irregularly shaped areas.
> > My goal is to have a end-to-end open source/GDAL workflow that converts
> the
> > bathymetric DEM to greyscale GEOTIFF which I can then use for further
> > processing/analysis using GDAL/OGR.
> > The convention in the offshore sector is to deliver bathymetric data as
> > single 'gridded' .XYZ ASCII file, where XY coordinate pairs are evenly
> > spaced to form a grid and the textfile row order is spatially sequential.
> > However, crucially 'nodata' values are omitted from the XYZ.  I can only
> > assume the reasoning was to reduce the file size on disc. This is an
> > industry convention that will not change anytime soon.
> > gdal_translate obviously does not read these XYZ files as gdal throws an
> > error due to the lack of true rectangular grid.  I've read the XYZ info
> > http://www.gdal.org/frmt_xyz.html which is clear to me, no problem
> there.
> > I do not want to use gdal_grid on the XYZ as this will introduce a
> further
> > interpolation step. The XYZs I receive are already cleansed and gridded
> by
> > the surveyor which I don't wish to edit further.
> > So, I currently use a proprietary marine geophysical package which can
> > directly read the gridded XYZ without nodata values.  Using this
> package, I
> > can export to ESRI ASCII grid (.ASC) which I then use gdal_translate
> > without issue for my further processing steps.
> > I'd like the freedom of a non-proprietary solution and the only thing I
> can
> > think of is to write a python script to pre-process my XYZ into a format
> > that gdal will accept.  I was thinking of calculating the XY bounding box
> > of the data and output an XYZ that blends the original values and nodata
> > values in the correct row order.
> > If anyone is interested, see below link to a zip of three separate
> > examples, containing:
> > -- 'gridded' XYZ (without nodata values)
> > -- processed greyscale GEOTIFF (using proprietary package)
> > -- processed color-relief RGB GEOTIFF (using proprietary package)
> https://dl.dropboxusercontent.com/u/4086367/gdal_translate_xyz_examples.zip
> > All data in these examples are referenced to SRS EPSG:27700.
> > If I've missed anything obvious, or if anyone has any thoughts of how I
> can
> > achieve my goal using GDAL or other, or comment on my proposed solution,
> > that would be greatly appreciated.
> What would be interesting is a link to a XYZ file that fails to be opened.
> In
> GDAL 1.11, I've improved the driver to be able to handle lines with missing
> values at their start and end. It might be possible to improve it again to
> deal with nodata values that would be at any place within lines. If the
> whole
> file is regularly gridded of course.
> > Thanks in advance.
> > Sam
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140525/0744800b/attachment.html>
