[gdal-dev] Multipolygon errors
Federico Jurio federicojurio at suremptec.com.ar
Mon May 26 12:33:43 PDT 2014
Hi, once again i'm here with an issue.
I am trying to rederize a multipolygon geometry without success. Here is
the wkt
POLYGON ((-54.874213174672484 34.043827148471607,-15.258888807860258
> 50.078601296943226,-15.258888807860258
> 5.432759550218335,-55.188620510917026
> 10.777684266375541,-54.874213174672484
> 34.043827148471607),(-49.843695794759817
> 29.013309768558948,-50.472510467248902
> 16.122608982532746,-20.603813524017465
> 11.720906275109165,-21.232628196506546
> 39.388751864628816,-49.843695794759817 29.013309768558948))
I have tried many different ways
*Case #1*
OGRGeometryCollection * pmultigeom = new OGRGeometryCollection();
int gerror = pmultigeom->importFromWkt(&pwkt);
*pwkt is a char* that contains the wkt that i have mentioned before.*
*Case #2*
OGRMultiPolygon * pmultigeom = new OGRMultiPolygon();
Result: In both cases importFromWkt() returns 5, which means
OGRERR_CORRUPT_DATA
*Case #3*
std::vector<OGRFeature *> featurecache;
for (size_t nfeat = 0; nfeat < totalcachefeatures; nfeat++) {
                  dynamic_cast<OGRGeometryCollection
*>(featurecache[nfeat]->GetGeometryRef());
Result: pmultigeom = NULL
*Case #4*
pmultigeom->addGeometryDirectly(featurecache[nfeat]->GetGeometryRef());
*Case #5*
            pmultigeom->addGeometry(featurecache[nfeat]->GetGeometryRef());
In both cases only shows one of the two geometries and i don't know why
only one.
Any advice would be greatly appreciated. Thank you for your time.
Best regards
Federico Jurio
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140526/a2b36bd6/attachment.html>
