[gdal-dev] RFC 46 GDAL/OGR unification adopted and commited
Even Rouault even.rouault at mines-paris.org
Tue May 27 02:46:35 PDT 2014
Selon Mateusz  <mateusz at loskot.net>:
I'd rather see frmts/mixed/XXXXX if XXXXX is a single driver that can return
both raster and vector content.
If you have a XXXXX (GeoRaster) and YYYYYY (OGR OCI) drivers that use common
code but remain separate, I'd say you can have frmts/raster/XXXXX and
frmts/vector/YYYYY and make one of them include headers from the other one. Like
it has been done up to now. Well if you want it to be cleaner, you could have
frmts/common/oracle and put in there the common code. However, if they are
plugins and not build-in driver, you should however make sure that both drivers
are bundled in the same shared object.
> On 27 May 2014 01:24, Ivan Lucena <lucena_ivan at hotmail.com> wrote:
> > What I am most interested is to have two driver
> > (that uses the same data container) sharing a little bit of code.
> > In my case I would like to have a folder structure to keep my two driver
> > under the same folder.
> > Something like that:
> > /frmts/container/
> > /frmts/container/vector
> > /frmts/container/raster
> > But that idea doesn't help with your concern about a large number of
> > sub-folders under /frmts.
> Ivan,
> You've touched an important issues - sharing of code between drivers that
> connect to the same data provider.
> My understanding is that drivers like Oracle or PostGIS would have the
> following structure:
> /frmts/mixed/oracle
> /frmts/mixed/postgis
> I'm not sure if I've grasped the idea well though.
> Best regards,
> Mateusz  Łoskot, http://mateusz.loskot.net
