[gdal-dev] Using GDAL with gridded XYZ that has no 'nodata' values?
Sam Franklin mailinglist.samfranklin at gmail.com
Tue May 27 06:09:37 PDT 2014
Hi Even. Great, that worked for me too when sorting on both columns.
Really appreciate you help.
Sam
On 27 May 2014 01:31, Even Rouault <even.rouault at mines-paris.org> wrote:
> Le mardi 27 mai 2014 00:06:33, Sam Franklin a écrit :
> > Hey Even - great tip.  The sort command you suggested worked well with
> that
> > xyz dataset.
> > However, I've found a further dataset that does not work with gdal even
> > after the sort. This is the error:
> > mbp-sf:data08 samfranklin$ gdal_translate data08-02-sorted.xyz
> > data08-02.tif
> > Input file size is 4371, 11210
> > 0...10...20...30...40.ERROR 1: At line 1100207, found 48162.000000
> instead
> > of 48164.000000 for nBlockYOff = 4951ERROR 1: data08-02-sorted.xyz, band
> 1:
> > IReadBlock failed at X offset 0, Y offset 4951
> > ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 4951
> > See screenshot below, the data is arranged into three 'strips'. See
> dropbox
> > link to the data |
> > https://dl.dropboxusercontent.com/u/4086367/data08-02.xyz.zip
> > Any workaround you can think of?
> Probably an issue with just sorting on column 2. I didn't have the same
> error
> as you, but anyway you should try :
> sort -nk 2 -nk 1 data08-02.xyz > data08-02-sorted.xyz
> with that I manage to translate the file.
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140527/8a4d124b/attachment.html>
