[gdal-dev] [Gdal 1.11]gdal_merge.py issue for merging tif
Rémy GOURRAT rgourrat at ag-carto.fr
Wed May 28 10:48:18 PDT 2014
I try to use gdal_merge.py on a windows server 2008 r2 intel.
So i installed Python 3.3.3 and gdal and gdal-111-1600-x64-core.msi<http://www.gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-1-11-mapserver-6-4\gdal-111-1600-x64-core.msi>
GDAL_DATA et GDAL_DRIVER_PATH are Ok, I check with trying an ogr2ogr from OCI to Shape with -a_srs EPSG.
When I do a "gdalinfo" d1.tif and "gdalinfo d2.tif" it's Ok.
But Every time I try to execute this script :
gdal_merge.py -o output.tif d1.tif d2.tif
I have this error message :
  File "C:\Program Files\GDAL\gdal_merge.py", line 35, in <module>
    from osgeo import gdal
ImportError: cannot import name gdal
During handling of the above exception, another exception occurred:
  File "C:\Program Files\GDAL\gdal_merge.py", line 37, in <module>
    import gdal
ImportError: No module named 'gdal'
do i need to install the GDAL-1.11.0.win-amd64-py3.3.msi , i think that's it just for AMD Processor, right ?
Thanks for your help
Rémy Gourrat
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140528/24db255d/attachment.html>
