[gdal-dev] VRTBuilder class
Gordon Farquharson gordonfarquharson at gmail.com
Wed May 28 12:27:54 PDT 2014
Thanks for the quick answer. Would the approach of turning GDAL utility
code into libraries be as simple as putting the code into .h and .cpp
files, or would you want to do it in a more globally organized way, e.g..,
to develop a sensible class hierarchy and a consistent naming scheme?
Gordon
On Wed, May 28, 2014 at 12:18 PM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> Le mercredi 28 mai 2014 21:03:40, Gordon Farquharson a écrit :
> > The VRTBuilder class in the gdalbuildvrt utility source code is very
> > useful. Is there any intention to make it part of the GDAL API?
> > Gordon
> Gordon,
> the idea of turning the code of GDAL utilities as library code reusable by
> user code has floated around. It probably waits for contributions and/or
> funding. In the mean time, you can "import" the code into your code.
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
Gordon Farquharson
GnuPG Key ID: 32D6D676
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140528/28f17145/attachment.html>
