[gdal-dev] ogr2ogr: Unable to open datasource [SVG, PDF] with the following drivers
Even Rouault even.rouault at mines-paris.org
Wed May 28 14:34:35 PDT 2014
Le mercredi 28 mai 2014 23:06:38, vous avez écrit :
> Hi Even,
> thanks for your prompt reply.
> Could you please tell more about the PDF limitation. For example a way to
> transform my PDF to the one that ogr2ogr would understand?
> I attached the test files.
The PDF driver would require some enhancements to support that kind of file.
Basically it currently only supports files that have a layered organization,
whereas yours is "flat". From a quick analysis, I'd say it would require modest
effort to support that file.
Geospatial professional services
http://even.rouault.free.fr/services.html
