[gdal-dev] ogr2ogr: Unable to open datasource [SVG, PDF] with the following drivers
klo uo klonuo at gmail.com
Wed May 28 15:24:34 PDT 2014
Ok, thanks for your confirmation.
I'll go DXF route.
In the meantime I found that by using pstoedit for conversion from PDF to
DXF is the right choice.
On Wed, May 28, 2014 at 11:34 PM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> Le mercredi 28 mai 2014 23:06:38, vous avez écrit :
> > Hi Even,
> > thanks for your prompt reply.
> > Could you please tell more about the PDF limitation. For example a way to
> > transform my PDF to the one that ogr2ogr would understand?
> > I attached the test files.
> The PDF driver would require some enhancements to support that kind of
> file.
> Basically it currently only supports files that have a layered
> organization,
> whereas yours is "flat". From a quick analysis, I'd say it would require
> modest
> effort to support that file.
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140529/7e038a2d/attachment.html>
