[gdal-dev] Store GDAL Result Raster in PostGIS Directly
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed May 28 19:59:23 PDT 2014
zlzhao1104,
Two things:
You need to specify the output data format using the -of option.
PostGIS raster driver doesn't support writing yet. It's being implemented
now.
It is more efficient to do that directly using an SQL command. Refer to
PostGIS docs.
Best regards,
Chaitanya Kumar CH
On 29-May-2014 6:42 am, "zlzhao1104" <zlzhao1104 at gmail.com> wrote:
> Hi I'm a new GDAL/PostGIS user.  This question might be simple to you:
> I need to use gdal_translate to clip a raster, which is already stored in
> PostGIS.  I could do it by using "PG" to link to my PostGIS database and I
> could store the result as a tiff file on my disk:
> gdal_translate -projwin -120.01969132 35.8820930603 -119.47058351
> 35.1172643251 "PG: dbname=geodb host=localhost user=postgres
> password=xxxxxx
> port=5432 mode=2 schema=public table=srtm_ca" test.tiff
> I'm wondering if there is a way to store the result raster directly to my
> PostGIS database as a table.  I tried to replace "test.tiff" above to
> "PG:......" but GDAL still generated a raster on my disk named "PG:......".
> Thanks in advance for any ideas and sorry to bother others.
> http://osgeo-org.1560.x6.nabble.com/Store-GDAL-Result-Raster-in-PostGIS-Directly-tp5143022.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140529/aa73b4a0/attachment.html>
