[gdal-dev] AREA_OR_POINT vs GDALMD_AREA_OR_POINT
Joaquim Luis jluis at ualg.pt
Thu May 29 12:58:36 PDT 2014
> It's a pity that the original
> > registration type is not preserved in GDAL so we could respect it.
> Is not preserved : through which operations ?
Through some form of metadata that would inform us that:
  "Although I'm reporting cell corner coordinates this file was
originally using cell center" (example case: Golden Software, AKA Surfer
format)
> > So let me repeat one of my previous questions, why was this ignored?
> > GDALSetMetadataItem(hDstDS, "AREA_OR_POINT", "Point", NULL);
> What do you mean by "ignored" ? Self-contained reproducable use case
> please ;-) I don't read in your mind.
Sorry that you can't.
I can't refer to a 5 liner example so I'll have to show some printings.
When I use
     GDALSetMetadataItem(hDstDS, "GDALMD_AREA_OR_POINT", "Point", NULL);
----- From GMT convert from netCDF to GeoTiff -----
grdreformat smt.grd lixo_MD_Pt.tiff=gd:GTiFF
Now gdalinfo shows "GDALMD_AREA_OR_POINT=Point"
gdalinfo lixo_MD_Pt.tiff
Driver: GTiff/GeoTIFF
Files: lixo_MD_Pt.tiff
Size is 256, 256
Coordinate System is `'
Origin = (-128500.000000000000000,127500.000000000000000)
Pixel Size = (1000.000000000000000,-1000.000000000000000)
Metadata:
Image Structure Metadata:
   COMPRESSION=DEFLATE
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( -128500.000,  127500.000)
Lower Left  ( -128500.000, -128500.000)
Upper Right (  127500.000,  127500.000)
Lower Right (  127500.000, -128500.000)
Center      (    -500.000,    -500.000)
Band 1 Block=256x8 Type=Float32, ColorInterp=Gray
   Min=-5000.000 Max=-1249.000
   Minimum=-5000.000, Maximum=-1249.000, Mean=-4941.563, StdDev=395.981
   NoData Value=nan
   Metadata:
     STATISTICS_MAXIMUM=-1249
     STATISTICS_MEAN=-4941.5626603216
     STATISTICS_MINIMUM=-5000
     STATISTICS_STDDEV=395.98068901299
However, if I do instead
grdreformat smt.grd lixo_MD_Pt2.tiff=gd:GTiFF
Than gdalinfo shows nothing in what regards the AREA_OR_POINT metadata.
This is what I was referring as "Ignored"
gdalinfo lixo_MD_Pt2.tiff
Files: lixo_MD_Pt2.tiff
Size is 256, 256
Origin = (-128000.000000000000000,127000.000000000000000)
   COMPRESSION=DEFLATE
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( -128000.000,  127000.000)
Lower Left  ( -128000.000, -129000.000)
Upper Right (  128000.000,  127000.000)
Lower Right (  128000.000, -129000.000)
Center      (       0.000,   -1000.000)
   NoData Value=nan
   Metadata:
> $ python
> Python 2.7.3 (default, Feb 27 2014, 19:58:35)
> [GCC 4.6.3] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> >>> from osgeo import gdal
> ds =>>> ds = gdal.GetDriverByName('Mem').Create('', 1, 1)
> >>> ds.SetMetadataItem('AREA_OR_POINT', 'Point')
> 0
> >>> ds.GetMetadataItem('AREA_OR_POINT')
> 'Point'
> > > Regarding the MEM driver, GDALMD_AREA_OR_POINT is just a random
> > > metadata item.
> > > Some drivers will set GDALMD_AREA_OR_POINT to the GDALMD_AOP_POINT =
> > > "Point" value.
> > > And the GTiff driver uses it to determine if it must apply a
> > > half-pixel shift between the GDAL convention and the GeoTIFF
> convention.
> > > Even
> > > > Hi,
> > > > I made GMT respect as far as possible the AREA_OR_POINT GeoTiff key
> > > > for read/write, but ...
> > > > The following was silently ignored (GMT uses the MEM driver)
> > > > so digging here and there I found about GDALMD_AREA_OR_POINT, and in
> > > > fact this one is now taken into consideration
> > > > However, this implies that on reading I have now to test for both
> > > > GDALGetMetadataItem(hDataset, "AREA_OR_POINT", NULL)
> > > > ---- AND ----
> > > > GDALGetMetadataItem(hDataset, "GDALMD_AREA_OR_POINT", NULL)
> > > > This means that other codes that pay attention to the AREA vs POINT
> > > > thing will have to do both tests as well and if they do only the
> first
> > > > one, GeoTiffs created by GDAL will have the problem ignored, and
> quite
> > > > likely an error in coordinates will follow.
> > > > So the question is, why this name duplication (AREA_OR_POINT vs
> > > > GDALMD_AREA_OR_POINT) and why GDALSetMetadataItem() ignores the
> > > > AREA_OR_POINT key?
> > > > Thanks
> > > > Joaquim
> > > > This message was sent using IMP, the Internet Messaging Program.
> > > > _______________________________________________
> > > > gdal-dev mailing list
> > > > gdal-dev at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > Geospatial professional services
> > > http://even.rouault.free.fr/services.html
